Update to latest eCtune Ver(0.0.2.3 r16) 07/31/10
Force update: Force update will update your ectune installation. Your settings files won't be overwritten. To force update, go to \"Start\" -> \"All programs\" -> \"eCtune\" -> \"eCtune force Update\". During the update you will see: After an update you will get the message: ---------------------------------------------------------------------------------------------------------- Steps if you want to do a clean install: -Save the following files: *C:\\program files\\ectune\\license.xml -Save the following folders: *c:\\program files\\ectune\\settings -Get the installer from http://websrv.ectune.com/ectune.setup.current.rar -Install ectune -Copy back the saved files & folders. -Run Force update ---------------------------------------------------------------------------------------------------------- Bug levels Level 1(minor bug fix) Level 2(Important bug fix) Level 3(Immediate update required) ---------------------------------------------------------------------------------------------------------- Zip/Rar update: http://websrv.ectune.com/ectune.update.current.rar http://websrv.ectune.com/ectune.update.current.zip
Change Log 0.0.18 r1 Special NOTE: Change the following in your cal. If you import an calibration the table will be still be the old table. If you create a new rom this is not an issue only with importing/using calibration from a previous rom base. Parameters-> Fuel & Ignition Correction -> Dwell ignition correction
Code: Select all
-Visual editing in percentage 3d/2d graphs - X -CTRL-J not always working(when you edit 2d/3d graph) - X -Button Record/COnnect/Save(mbter) - X -ELD as o2 input - X -Save as doesn't add extention on new bin create(nick/randy/frank) - X -Keypress tables and adv table(dave) -Moates Burn1 - X -Notify if an input is already in use(randy)- X -Copy scalar rpm - X -Copy Scalar map - X -If doing boost retard on tables, don't let tables retard below 0 degrees(chriss) - X -Remove vtec checkbox(confusing for some people)(frank) - X -Bytes left for update changed updating display each 100 bytes - X -Lookup LC-1 default values -overall fuel trim inj calibration not updating rom - X -zeitronix wideband(rene) - X -Update shortcut to reflect new graph editing - X -Interpolation buttons not always enable when selecting cells(chriss) - X -Add aem 5bar map sensor(nate) - X -Shortcut keys for 2d/3d/live plots/clear live plots/SHow & hide graphs - X (see shortcut keys) -windows size and location in registry(burgermass) -X -2d/3d deselection didn't work(nate) - X -ROM: *Starter signal replacement - X(tested) *Fuel cut delay - X *Fuel Pump control normal/always on/always off(nick) - X *Bug alternate control - X(tested) *BUG mil codes not showing - X *Change Dwell rpm ignition correction to relefect rpm> 8950 - X -removed burn1 settings tab, no need for it - X
0.0.1.8 r2 0.0.1.8 r3 I think a lot of small bugs with datalogging and adv table should be solved now. Feel free to press f1 everywhere I have put exented debugging in the settings. If you still get JIT or Incorrect format send everything. I don't have these issues on my pc's. So i need all the info what you did when how etc..
Code: Select all
- bug with smooth map - X - smooth selection shortcut not working in graph mode - X - math.round temperature(crhiss) - columns not working fuel and ign settings(chriss) - X
Code: Select all
- Bug with Check update from ectune help menu - X - Option always realtime update - X - Move update server to eCtune.com - X - Advance table graph changed(dave) - X - Advance graph for Injector battery offset(dave) - X - Advance graph updates when chaning the table value - X - 2d/3d graph shown NA portion of graph only(dave) -X - If no adv graph disable menu item show 2d graph - X - Save afr reading after changing config(frank) - X - 2D button for advance graphs - X - 2d/3d graph showing NA columns only(dave) -X - Bug when entring edit mode table and adv tables - X - ESC to cancel change during visual editing(nate) - X - MSI remove installation(civic_tsi) - X - Graphs for GPO ign & fuel corrections - X - Load datalog after recording not saved in config bug(frank) - X - Disable upload cal while realtime update(mbter) - X - F1 helpprovider for windows/parameters - X - [b]Handle canInvoke bug[/b](dave) - X - [b]Debugging in settings file[/b](check for corruption)(post detailed info) - X
Updated again. removed the JIT bug. I was able to reproduce it. Chris gave me the exact steps
Code: Select all
JIT settings bug - X
Update 02-may-2007: Version 0.0.1.8 r4 Updates/Fixes/New features:
Code: Select all
0.0.1.8r4 Rom Updates: - Mil version ID(hackish) - X - Fuel pump prime time(cj) - X - Minium ect closeloop - X - Diasble Code 1 in openloop tps based - X - ect overheat protection(hackish) - X - IAT correction trim(dave) - X - Disable upload calibration when Realtime update active(mbter) - X - bug Temperature values showing as double - X - ect overheat protection - X - Settings are saved when you leave a textbox/parameter(dave) - X - Table grid and advance table grid press spacebar to edit - X - Burn1 comm port cached(faster burn1 acces)(nate) - X - Burn1 window not always on top - X - Ostirch verify bug(civic_tsi) - X - Ostrich fatal crash if cable removed(civic_tsi) - X - Peak display datalogging display(nate) - X - target o2 volt change(float/rouding) - X - MPH for vss not working(locash) - X - Control-P toggle Parameters(open/close)(locash) - X - Make R interpolate rows(locash) - X - Make C interpolate columns(locash) - X - Datalogging try auto reconnect after timeout(locash) - X - Context menu item smooth map and smooth selection seperate(locash) - X - TImemout msgbox behind ectune(locash) - X fixed with datalogging auto reconnect - Smart tracking types(hackish) - X - Bug injector calibration causing expection - X - Display voltage tps calibration - X - warning color for battery(locash) - X - Port cache for emulator(auto scan) - X - Port cache for datalogging(auto scan) - X - Basemaps: d15b jdm vtec p08 - X h23 - X - Buttons Peak display and peak clear - X
Update 10-may-2005 Update 0.0.1.8 r5 Updates/fixes/bugs resolved:
Code: Select all
- Rom 0.0.40: - Closeloop Bug - X - Ign adjustment - X - selected node color in graph mode(hackish) - X - selected node type in graph mode(hackish) - X - Bug injector calibration alpha characters(dave) - X - Single cell select graph mode with right mouse button(hackish) - X - STD/ABS filter disable(burgermass) - X - Basemap versions from directory - X - Tuned Maps/Table Exports from directory - X - Check all events related to emulator and datalogging - Emulator - X - Check Calibration Area version 36-40(burgermass) - X - Wideband closeloop default settings when enabling wideband closeloop(frank) - X - Widbeand afr->volt lookup(frank) - X - Rename put baserom(frank) - X - Bug calibration not opening(civic_tsi) - X - error code icon view->error codes(nate) - X - Boost table setup new icon(nate) - X - Use secondary maps only new icon(nate) - X - use high cam maps only new icon(nate) - X - 2d graph new icon(nate) - X - Help icons(nate) - X - IACV error didn't save(nate) - X - Fuelpump prime time(nate/civic_tsi) - X - Decreament fuel table bug(hackish) - X - Out of index when in 2d graph mode(hackish) - X - frank rom incr/decr first column doesn't work - New interpolate(hackish) - X -X interpolate -Y interpolate -XY interpolate - Bug AFR target change slow when graph open - X - Shift key for selection works in 2d graph mode(hackish) - X - Bug overall fuel trim not saving(burgermass) - X - G to select current cells(while tracing, grab the current trace cell)(hackish) - X - ROM BUG o2 trim/closeloop Fixed in version 0.0.37 to 0.0.40 - X
Update 07-June-2007 Update 0.0.1.8 r7 Updates/fixes/bugs resolved:
Code: Select all
-------------- v 0.0.1.8 r6 - Fixed peak buttons(frank) - X - Rom Updates Rom version 0.0.42: - GPO activate VTS maps(nate/burgermass) - X - VTS MAPS ORDER - Highcam Only Bit - GPO 1 vts map bit - GPO 2 vts map bit - GPO 3 vts map bit - GPO 2 - X - GPO 3 - X - EBC iat compensation - X - EBC rpm compensation - X - EBC Target PSI tps multiplier - X - Recorved rom space - X - IAB output invert - X - Datalogging code update -fractional of the interpolation - X -Snapshot of rpm/map cell(prevents crossing) - Removed dead code - X - Changed mem location PA sensor - X -0.0.42 - Redid wideband closeloop hopefully good - X -0.0.43 - Alhpa-n - X - Tps indexing - X - Removed lots of dead code - x - Re-enabled a fuel enrich/lean based on delta tps - X - More dwell related tables(dave) -Rpm dwell correction table - X -Battery dwell multiplier table - X - IACV duty cylce(test) - X - Expose full tps tip-in retard - X - EBC: Minimum and maximum duty cycle allowed - X - Stock variable minimum ect for closeloop opertation-X - EBC tested with a scope.. Hz and duty cyle with invert - X - Shortcut for smart tracking(hackish)(Alt + T) - X - Wideband Egr lift input, b6 input - X - Save Overlay AFR(burgermass) - X - Different target for primary and secondary maps - X - Different target for low and high cam maps(neil) - X - GPO enable checkbox enables/disables GPO parameters - X - Out of index graph mode with shift key press(hackish) - X - Click select graph mode 2d(left mouse button) - X - Drag selection only when pointer is on one of the selected nodes - X - Drag sqaure to select left mouse button - X -All graph selection/% change are on left mouse now - X - Press control in graph mode to select multiple cell with your mouse - X - Cell trace single/quad with fractional of the interpolation - X - PA value with PA disabled(Frank) - X - G should switch maps and select high cam(hackish) - X - Peak display INjector info(duty cylce)(hackish) - X - Shift in graph mode slow with large selection(hackish) - Copy paste graph don't update graph(civic_tsi) - X - Upgrade rom show old version(civic_tsi) - X - Tested fuel pump prime time - X - Shorten the MIL id time - X - Hardcode Ctrl - J(hackish/nick) - X - Bug with USE PA as mBar Sealevel - X - The VTEC map, when graph mode is enabled, will fill with \"blue\" cells as the trace gos trhough the map. It is NOT the smart tracking, but the actual cursor. - UNABLE TO REPRODUCE - CTRL-J bug(hackish/nick) - X - Test emulator busy pull USB -> throws error then disconnect - X - Test datalogger busy pull usb -> throws error - X - Friendly message for webupdate error - X - Throw Code 6 doesn't save(nate) - X - GPO enables/disable grey out(nate/chris) - X - MPH math.round(nate) - X - Alpha-N Scalar Setup - X - bug with non auto-scan datalogging not connected(nick/nate) - X - If disconnect Ostrich while busy, eCtune taked 100% cpu. Then I click disconnect and ectune will either crash or return to normal.(nick) - TOolbar icon interpolate XY - X - Faster realtime update, updates byte left on screen each 100 bytes send - X - Wrong adresses for ebc output and retard(cj)-X -----------------------------------------------------------
Code: Select all
v 0.0.1.8 r7 -0.0.44 -Expose rpm differance between cut/resume for FTL/FTS(nick) - X -BUG output control - X -BUG VTS map switch - X - overall fuel trim wont allow negative integers in injector calibration(nate) - X - Fuel trim validation/tab order - X - Selectin Kpa/kpa in settings-units, cause crash(nate) - X - Processor load 50% on pulling USB(emulator/datalogger)(nate/nick) - X - Hibernation with emulator connected, crash & processor time(nate) - X - Set and reset ftl rpm(nick) - X - Copy and paste advance tables - X - Datalog play and scroll crash(nate) - X - ign anti-lag validationg textbox(mbter) - X - Disable Allpha-n/TPs scalar based on load type(nick) - X - Alpha tps start column validation(nick) - X - Position toolbar and windows regsitry bug? - - Gear 0 recording(Xenocron/civic_tsi) - X - Zoom and move scroll bar crashes etune(nate) - X
Update 16-July-2007 Update 0.0.1.9 r1 Updates/fixes/bugs resolved:
Code: Select all
v 0.0.1.9 -0.0.45 Rom -ECT idle 1/2 -moving - X -Expose Idle Ignition correction - X - CTRL-J validation - X - Bug with open calibration(cj) - X - Import/export calibration last folder(nick) - X - BUg toolbar(nick/nate/civic-tsi) - X - Bug test datalogging settings menu(cj)-X - Bug b6 input(allan) -X - Analog 2 not working(JDM/USDM) - X -Solution found hardware differance - X - new licensing - X -LICID in binary/calibration -Protect maps - -Password protect on startup - X - Webupdate delete base_rom folder - X - new basemap in tuner version, enable import calibration - X - Basemap creator scroll - X - Closeloop settings add closeloop trim(cj) - X - When setting AFR(closeloop) use offset in formula(yc underground) - - Closeloop trim => inject mult(Cj) - eCtune slow during multiple cells select in graph mode(nick/hackish) - Auto scan debug file and test(dave/nate/jd) -Trace function for problem users - X - VSS graph is always in kmh(dave) - X - Burn1 read and open p30/crome bin crash(nate) - X - On Startup Load Last Rom is enabled, when eCtune crashes it tries to autoload the invalid rom the next time eCt is loaded causing a crash again(nate) - X - BUg af overlay wrong adjustment(burgermass) - X - Requested Files(no bug seen here) - X - OVerlay map should show est fuel change not differance - X - Bugs with commport on pull USB - X - Minor bug datalogging routine - X - !!!!Datalog file with headers, markers & comments, multiple version - X -New version datalog saves everything - X - Stoich value with drop down - X - Wideband closeloop o2 trim not saving when narrow->wideband(frank) - X - Bug AFR/Lambda display item(frank) -X - Bug Afr/Lambda data grid(frank) - X - Multipe bug with storing lambda/afr(frank) - X - RPM scalar EBC(dave) - X - Peak dispaly Metric value map sensor(frank) - X - Graphs all new sensors - X - Bug graph analog 3 not save correctly in log file - X - Default cancel button basemap creator - X - Default accept button grid adjustment(frank) - X - rpm plot for metric(frank) - X - time plot for metric(frank) - X - Small bug 2d graph advance tables - X - Map display alpha N(allan) - X - graph alpha-n/tps display - X - Interpolation with alpha-N(allan) NOT a BUG - TPS tip-in check values(dave)- Working - 2 instance bug(frank/hackish) - X -Due to auto scan trace.txt - Upgrade not working?(hackish) - X without emulator - Working with emulator- Fixed - Single click header row/column full select(xenocron) - X - Bug auto-scan when in ectune_isr mode(linked port)(nate) - X - Bug emulator didnt disconnect if datalogger ubs pulled(linked port)(nate) -X - Patches datalogger version - X - Datalog with comments - X - Gui for marker comments - X - Datalogging verion patches(nate)-X - Datalogger marker tool strip button bug(nate) - X
Code: Select all
v 0.0.1.9 r1 -0.0.46 Rom Delevlopment - Mbar change honda sensor -70 mbar - X - Fan control default output FANC - X -Static retard value for Anti-lag(chriss) - X -3Step/Rev limits *Gear depended rev limit(timdog) - X *Hard coded hot and cold rev limit(Gaskleppie) - X *FTS gear depended - X *FTS tps threshold - X *FTL memory set with button(chris/JD) *FTL primary/secondray maps(chris/JD)SKIP memory good enough *Rev/Burnout with button(chris/JD) -Ebc *EBC hz *EBC outputs *Scramble input *Closeloop based on deltaMap -IAT error -VSS error -Alternate VTS output -Target o2 map instead VE -Mil shift call(delay in rpm)(dave) -Soft rev limit(burgermass/hackish) - datalog file comments not saved on reopen(nate) - X - Basetiming below 16 bug(arthur) - X - ISR overflow ROMulator(CHriss) - Disabled Use dt port - X - Waiting on reply - XY interpolate enabled with 1 cell selected(nate) - X - Bug eCtune staying open on datalog play(nate) - X - Auto memory garbage collect - X - Bug datalogger version. Export/save latest download cal - X - CTRL-J validation escape worked for 1 textbox(allan) - X - Boost display(peak boost)(nate) - X - Tooltip datalogging comment truncate(nate) - X - Add note icon when mouse over marker with no comment(nate) - X - eCtune staying open on datalog playing and graph open(nate) - X - Bug time display graph longer then 1 hour - X - Bug cursor pixel in log graph - X - Idle ignition correction bug value entry - X - Old injector size in binary - X - change honda 1.75 mbar min mBar to -70 - X - Ecu type p72 didn't set right options(nick) - X - Fan control output default(chris) - X - Bug filname if rom selected from MRU - X - Press write twice on burn 1(allan) - X - Streamline get rom datalogger version(nate) - X - Spelling errors - X - O2 trim NB->WB->NB(civic_tsi) - X - Analog input hardware information(allan) - X - Datalogger buttongs disabled with no log open - X - emulator menu disabled in datalogger mode(chriss) - X
Code: Select all
v 0.0.1.9 r2 -0.0.46 Rom - Mbar change honda sensor -70 mbar - X - Fan control default output FANC - X - Mil shift call(delay in rpm)(dave) - X -Static retard value for Anti-lag(chriss) - X -3Step/Rev limits *Gear depended rev limit(timdog) - *Hard coded hot and cold rev limit(Gaskleppie) - X *FTS gear depended - X *FTS tps threshold - X - Patch usb error handling- X - Edit graph template icon(nate) - X - Refresh if settings changed(dt graphs)(Nate) - X - ecu o2 volt and wb volt (dido) - X - sample rate not saving - X - delete unsaved datalog if you select no - X - bugs not going in to timeout mode - X - add comment icon stay after adding comment - X - Fuelcut not showing in graph - X - Log load performance(thread) - X - Log graph draw performance - X - Set target afr bug with cal closed(nate) - X - Copy and paste bug afr grid(yc underground) - X - Input in use KEOE TPS(civic tsi)-X - boost settings page removed(nate, civic tsi) - X - MRU bug(file not exist anymore) - X - graph mode show select node map value/rpm(hackish) - X - Parse fill log file and fill afr tables(nate) - X - Put check to detect J12 in place when trying to log - X - Hard code ISR BAUD - X
Code: Select all
v 0.0.1.9 r3 -Rom 0.0.46 - Fix koeo bug - X -Rom 0.0.47 -Boost cut 1200 rpm bug - X *FTL memory set with button(chris/JD) *FTL primary/secondray maps(chris/JD)SKIP memory good enough *Rev/Burnout with button(chris/JD) -Ebc *EBC hz *EBC outputs *Scramble input *Closeloop based on deltaMap -IAT error -VSS error -Alternate VTS output -Target o2 map instead VE -Soft rev limit(burgermass/hackish) - Fixed set target afr bug - X - Fix esc/close ctrl-j - X - Fix esc/close timing sync - X - Honda map sensor default ectune -70 mbar - X - Below table text - x - Map sensor value editable in PSI,mbar,bar,kpa,inHG - X - Mbar value in live graph - X - Disable GPO during ftl/fts/anti-lag - X - Messagebox if the software will expire-X
Code: Select all
v 0.0.2.0 -Rom 0.0.46 - Fix koeo bug - X -Rom 0.0.47 -Boost cut 1200 rpm bug - X -Boost cut 1200 rpm default - X - Fixed basemap creator pr3 vtec point -X - Boostcut current/1200 rpm fix - X - Boost cut 1200 rpm default for basemap creator - X - Bug emulator rom save - X - Paramaters Layout - X - Ostrich 1 and 2 detection bulk/normal writes - X - Licensing - Exp dates - X - Single Car license - Ostrich Encryption - X - Ostrich XML - X - Single Car Pro options - HID bug in vendor DLL - X -Msg when ectune will expire - X
Code: Select all
v 0.0.2 r4 ***Note: Comments/Options/Features with X or finished or coded -Rom 0.0.48 -Alternative VTS output - X -Fix altenator disable Bug - X - Bug ostrich fimware 12 bulk write - X - Bug selected index graph template(xenocron) - X - Open last rom/cal in datalogger version security bug(civic tsi) - X - Decimal comma bug Stoich - X - Single Car license - Single Car Pro options - X - Ostrich Registration Webservice -X - Update for All version(removed base_rom folder from normal update) - X - Reporting Webservice(license tampering) -X - Single cell trace move based on rpm/mbar fraction(hackish) - X - Weigh primary cell when storing afr for tuning(hackish) - X - Graph load heading refresh when updating setting(hackish) - X - File extention save as based on opened file and seletect type(civic_tsi) - X - Save as binary menu item(civic_tsi) - X - Auto save datalog on disconnect/stop datalogg with button(burgermass) - X Datalog save folder current or other - X - Bug ostrich 1 write - X - Spelling errors(micheal) - X - Analog input 1 enabled for all versions, 2 and 3 for tuner only - X - Bug auto-scan if old port is invalid(nick) - X - Stock rev limter p72 fixed(nick) - X - Pro license bin save bug - X - Disable \".bin\" extention in save as dialog pro version(nick) - X - Tuner/Dev version can gen/set a ostrich serial and work \"unlicensed\" with it - X - Bug realtime update ostrich ectune - X - Debug window for datalogging connection(nate) - X - Weigh trace only on rom with datalogging fraction(hackish) - X - Renamed/fixed TPS Tipin ignition correction - X - Output list changed VTEC output removed and used Altenator Control - X - Icons datalog auto save, peak show and peak reset update - X - Step retard regional bug(allan) - X - Overall fuel trim calculator - X - Spelling error rom upgrade(hackish) - X - Scroll bar vtec parameter(hackish) - X - Bug dialog save binary(hackish) - X - Smart tracking based on primary cell(hackish) - X - Ostrich version > 10.15 enable reset in ostrich info when normal ostrich v1 or v2 selected-X - Open/New file with all windows closed expection(st00pid) - X - Emu baud ostrich not saved(always set to 921600) fixed(nick) - X - Base map creator slow bug - X
