Minimizing a window :Solved:
When you minimize a window (IE data, parameters,display), then you try to restore it, it comes up shrunk down and you have to drag the edges to make it big again.. While your working on that, one thing that would be nice, is if say you minimize the parameters window, and you hit the parameters button again it would restore the window.. Same for all the windows activated by buttons at the top..
I'll look into it. I notice it too.. But had to fix other issues first. I'll make a button to snapshot the current screen settings. what is open, where and how big. If you click that everything gets restored.
Consider it solved. I'm putting those settings in the regsitry now, instead of .net user.config. So the locations/sizes doesn't change if the software is update to a higher version.
