Page 1 of 2
Possible random code 10 or code 1?
Posted: Fri Nov 30, 2007 1:03 am
by mtber
I have had two customers contact me telling me that they had a random code that is a single flashing code. My guess is a code 10 as they said it was kind of a long flash.... Both customers are on v 0.0.2.0 using a .46 base. Anyone else see this issue ? VE/O2 Disabled on both cars.... Thank You, John Vega
Posted: Fri Nov 30, 2007 7:33 am
try the closeloop+ve disable(stock) instead
Posted: Fri Nov 30, 2007 12:17 pm
by mtber
calvin wrote:try the closeloop+ve disable(stock) instead
It is/was. Everything was disabled.
Posted: Fri Nov 30, 2007 3:51 pm
the stock option? There is stock closeloop+ve disable and 2 seperate one Closeloop disable VE disable. Try using the first option only
Posted: Fri Nov 30, 2007 4:07 pm
by mtber
calvin wrote:the stock option? There is stock closeloop+ve disable and 2 seperate one Closeloop disable VE disable. Try using the first option only
Will this fix the issue or is it just a guess ?
Posted: Fri Nov 30, 2007 6:05 pm
gues.. I never had that problem. But i can think of something so try that
Posted: Fri Nov 30, 2007 6:20 pm
Maybe there is a small hickup in your bin. Try to export the maps, make a new bin and import the maps. Set the settings to there original values and try again. I never had or seen this problem also.
Posted: Mon Mar 03, 2008 1:07 pm
by mtber
Using the latest devel version with .54 bin I did not click \"closeloop+ve disable(stock)\" and I have a customer reporting a random code 10. Is this bug still around ? I assumed the bug was resolved so I didn't select disable \"closeloop+ve disable(stock)\"
Posted: Mon Mar 03, 2008 4:06 pm
by Bindegal
I have never heard of this from any of the cars I eCtuned... Admittedly, most of them leave my hands with closed loop carefully tuned and enabled. Could it not be an intermittant IAT sensor problem? (CEL=10) /Allan
Posted: Tue Mar 04, 2008 2:49 am
by mtber
Bindegal wrote:I have never heard of this from any of the cars I eCtuned... Admittedly, most of them leave my hands with closed loop carefully tuned and enabled. Could it not be an intermittant IAT sensor problem? (CEL=10) /Allan
I doubt it as the car never had this issue while tuning on the ostrich/laptop. I had one other customer with this issue...
Posted: Tue Mar 04, 2008 4:32 am
I have a few cars riding on 0.46 but none of them has reported any error codes to me.
Posted: Tue Mar 04, 2008 11:17 am
ectune does nothing/modding code near IAT/IAT error. If it's code 10 it's a realy code then or the guy can't test/read codes. i never had the code one some of u are reporting.
Posted: Wed Mar 05, 2008 8:46 am
btw i never fixed any bug regarding o2 code. I just say try the other methode. that is stock the closeloop disable only is a custom routine based on the tps disable of closeloop
Posted: Thu Mar 13, 2008 5:45 pm
by mtber
The issue did not occur for me on my p28 with the romulator. I disabled \"closeloop+ve disable(stock)\" and re-checked the tune & reburned the chip. The random code 10 went away thus far.
Posted: Thu Mar 13, 2008 5:49 pm
then it won;t be 10 for sure more like 1 o2 code.
