High Cam Only Map Selection Does Not work
I am trying to do a Single Cam Non VTEC that is revving higher than 8000 so I wanted to use the VTEC Maps only so I have table cells above 8000 rpms. If I selected the HIGH CAM MAP ONLY under Fuel & Ignition Table settings, it is still using the Low Cam Fuel and Ignition maps...
Thanks...
Unfortunately I had to tune the car on the low cam maps only...I was in the middle of the tune when I posted the bug and didnt see your email until after I was done tuning
i cannot see in bench mode... I'll have to test in the car. Can somebody else maybe test.. Just a running car.. Select high cam only and then see if it switch to VTC maps
I will try today in a car I have here at the shop...
My car died...I spent the whole time today trying to fix it
Confirmed working with Calvin last night.
