Autodetect test fail lockup
blundar
Post by blundar »
1. Unplug ostrich 2. In settings, click \"test\" under ostrich settings 3. Application locks up, must be killed in task manager 1. Unplug datalogging cable 2. In settings, click \"test\" under datalogging settings 3. Application locks up, must be killed in task manager Unless there is success, the \"test\" feature seems to just lock up eCtune.
z31
Post by z31 »
I just tried everything in the same steps that you listed and didn't have any sort of lock up. I'll post the screen shots (if need be) that I saved of the program doing it's job correctly and not finding both connected and still not locking up. Connecting both, I can resume just like normal. I'm using the most current version available to me 2.0 r6.
it doesn't lock up here. I guess something with FTDI drivers? It should lock up. I'll have a look. Only thing i can think of that port doesn't disappear on unplugging and causing a lock up
Adam Hopkins
Post by Adam Hopkins »
I also tested exact steps, It is not locking on me,
