You've got pm. Hopefully it explains in better detail this timecalvin wrote:Now who will do the closeloop write up.
FAQ: Xenocron write up EBC/ eCtune EBC PDF
Is this write-up current and correct? I just installed mine and for some reason it was always just spiking straight to boost cut. I triple checked everything and then noticed that in the write-up for configuration when \"Normally closed\" is selected Minimum is %100 and maximum is 0%. In my version of ectune it was the opposite. I tried to switch the text box values but it wouldnt let the min be higher then the max (obviously). I ended up just selecting the normally open radio button and it works perfectly, even though it is acting like it is normally closed. Not sure if its me or not, but maybe something to look into with updating the instructions. Other than that everything worked great!
I'm also having this problem, how did you fixed it? I switched to normally open but I'm only making peak 7.5 psi, my wg spring is 8.5. usdm p72 with xenocron ecu components. wired to a11.sohcd16y8 wrote:Is this write-up current and correct? I just installed mine and for some reason it was always just spiking straight to boost cut. I triple checked everything and then noticed that in the write-up for configuration when "Normally closed" is selected Minimum is %100 and maximum is 0%. In my version of ectune it was the opposite. I tried to switch the text box values but it wouldnt let the min be higher then the max (obviously). I ended up just selecting the normally open radio button and it works perfectly, even though it is acting like it is normally closed. Not sure if its me or not, but maybe something to look into with updating the instructions. Other than that everything worked great!
I would think so too but before i put the ebc in I was making 8.59 but now its only showing peak 7.51 in ectune...I'll play around with it some more.sohcd16y8 wrote:There is no way the solenoid will cause you to make less boost then your wg spring pressure. Either you have the incorrect spring, bad source, or something else is wrong.
