Page 1 of 4
				New laptop - locked out
				Posted: Fri Jan 25, 2008 11:17 pm
				by 2kCivicSi
				I'm already emailing Calvin on this but don't have a solution to the problem yet.    I finally got upgraded laptop.. new Dell Precision M90.  old laptop is traded in.    I tried installing the installer version for 0.0.2.o r6 but can't get into Ectune long enough to register it..  it crashes immediately after the splash screen shows.    If I try to copy my old license.xml file into Ectune, it opens but gives me error 004h telling me to email ectune.. when I click OK to that, it closes immediately.    Is there something I did wrong?  Or something I should do that will allow me to register and continue?    Maybe you should make a Register applet separate from the main program?  Or when the program opens with no valid license, it require you to register rather than crash or simply close..
				Posted: Fri Jan 25, 2008 11:27 pm
				by Joey Misanthropy
				The licence file is tied to your machine ID, which is unique to each laptop.  You're SOL until Calvin pushes a few buttons on his end.
				Posted: Fri Jan 25, 2008 11:29 pm
				by 2kCivicSi
				the part where I seem to be really screwed is I can't even get in far enough to click 'register' to get the new license...
				Posted: Sat Jan 26, 2008 12:30 am
				by z31
				Have you tried to get a hold of Calvin on any of his messengers like msn, aim, skype? He's never left me hanging and he's always been extremely helpful. I'm sure he'll get this fixed very quickly. When did you send the email anyways?
				Posted: Sat Jan 26, 2008 1:15 am
				reinstall laptop and try again. try on an other pc. then you will see it works
				Posted: Sat Jan 26, 2008 7:26 am
				by 2kCivicSi
				unfortunately, reinstall on this laptop isn't an option.  It's work laptop.      I have all Windows Updates installed... .net 1.0, 1.1, 2.0, 3.0, etc.. everything updated.
				Posted: Sat Jan 26, 2008 12:21 pm
				by sohcd16y8
				Take your old license out of your ectune folder and will will run as a datalogger again. Then request a new license.
				Posted: Sat Jan 26, 2008 6:43 pm
				by 2kCivicSi
				I did take the license out.    With the old license in, I only get an ECTune error (004h) and the application closes normally.    With no license, I get the above crash.    Aside from the applications my MIS dept installed before I got it, the laptop was fresh out of the box from Dell.  They are the same applications (mostly) that I had on my previous laptop, with the exception of Office 2007.  Getting all the work applications reinstalled is a 4 hour babysitting job - they aren't going to let me wipe the drive very easily..
				Posted: Sun Jan 27, 2008 4:37 am
				by Bindegal
				The weird thing is, I can fire up eCtune no problem on a Vista preloaded Thinkpad and HP laptop, no problem.    My $0.02:  -Make sure you have admin rights.  -Disable UAC.  -Uninstall eCtune.  -Delete eCtune folder.  -Reinstall eCtune.  -UnZip update over original files.  -Don´t bother copying the old license. You need a new one anyway.  -Start it up and see what happens...    /Allan
				Posted: Sun Jan 27, 2008 8:54 am
				by 2kCivicSi
				This isn't Vista... it's Xp Pro.  And I have full Admin rights. (Add/remove/change settings, etc..)    Is there still some sort of User Account Control I need to be worried about?    What update(s) are there?    I have a fresh copy of 0.0.2.0 r6 installer from the server..     When I tried to put the update in, every file has same time-stamp and size..
				Posted: Mon Jan 28, 2008 1:16 am
				Completely uninstall and remove old license (thus deleting eCtune folder after uninstall).    Once done, reboot, then install eCtune again, this still causes the program to crash?  sounds very odd if so;      A reboot can do wonderous things in XP;  Vista normally doesn't need it anymore.
				Posted: Mon Jan 28, 2008 9:55 am
				by nate
				I had the same thing a while back and was not able to resolve it until I reinstalled windows completely.     Even though you uninstall eCtune I don't believe the uninstaller has been updated to remove ALL the components, and therefore a uninstall/reinstall of eCt does not fix. We really need to get the installer 100% so hopefully things like this in the future won't be so tough...    That's my .02c anyway...
				Posted: Mon Jan 28, 2008 7:38 pm
				that is what i said too..  I think it has much to do with the encryption program i use
				Posted: Mon Jan 28, 2008 9:58 pm
				by 2kCivicSi
				If you know the names of the files used... can you email me so that I can remove them manually?    Barring I purposefully crash my laptop, I won't be able to do a full reinstall..
				Posted: Mon Jan 28, 2008 10:13 pm
				well i never found out what nathans problem was..  So i cannot tell u
