Index was out of range....
I got an error, this one I don't think I can produce steps; I left eCtune on, played with a cal, and saved then left eCtune in the background at that moment in time minimized. When I pulled eCtune to the top to go back over it some hours later, on maximize I got this error:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index at System.Collections.ArrayList.get_Item(Int32 index) at System.Windows.Forms.Layout.ArrangedElementCollection.get_Item(Int32 index) at System.Windows.Forms.Layout.FlowLayout.xLayoutRow(ContainerProxy containerProxy, ElementProxy elementProxy, Int32 startIndex, Int32 endIndex, Rectangle rowBounds, Int32& breakIndex, Boolean measureOnly) at System.Windows.Forms.Layout.FlowLayout.LayoutRow(ContainerProxy containerProxy, ElementProxy elementProxy, Int32 startIndex, Int32 endIndex, Rectangle rowBounds) at System.Windows.Forms.Layout.FlowLayout.xLayout(IArrangedElement container, Rectangle displayRect, Boolean measureOnly) at System.Windows.Forms.Layout.FlowLayout.LayoutCore(IArrangedElement container, LayoutEventArgs args) at System.Windows.Forms.Layout.LayoutEngine.Layout(Object container, LayoutEventArgs layoutEventArgs) at System.Windows.Forms.Control.OnLayout(LayoutEventArgs levent) at System.Windows.Forms.ScrollableControl.OnLayout(LayoutEventArgs levent) at System.Windows.Forms.ToolStripPanel.OnLayout(LayoutEventArgs e) at System.Windows.Forms.Control.PerformLayout(LayoutEventArgs args) at System.Windows.Forms.Control.System.Windows.Forms.Layout.IArrangedElement.PerformLayout(IArrangedElement affectedElement, String affectedProperty) at System.Windows.Forms.Layout.LayoutTransaction.DoLayout(IArrangedElement elementToLayout, IArrangedElement elementCausingLayout, String property) at System.Windows.Forms.Control.OnResize(EventArgs e) at System.Windows.Forms.Control.OnSizeChanged(EventArgs e) at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight) at System.Windows.Forms.Control.UpdateBounds() at System.Windows.Forms.Control.WmWindowPosChanged(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
