Revlimit hot/Cold threshold not saving value:
Posted: Sun Feb 17, 2008 4:10 am
Using current release 0.0.2.0r7 Go to parameters: Revlimiter Settings Revlimiter hot/cold threshold: set to 160. Save cal and close eCtune reopen eCtune, and cal, back at 140. If it does not do it with yours, I will post my .cal, but it should be the same as the current in the posted .BIN's folder.
Posted: Sun Feb 17, 2008 10:21 am
by Almighty-Si
I just went through those steps and it does the same to me as well. Also on version 0.0.2.0r7
Posted: Sun Feb 17, 2008 5:58 pm
Ok i'll look into it
Posted: Mon Feb 18, 2008 9:02 am
by Civic Tsi
Doesn't do it on 2.1 r1
Posted: Mon Feb 18, 2008 3:08 pm
works on 2.1 r1 tested it too
Posted: Mon Feb 18, 2008 4:54 pm
Cool. I'll sit tight. The last 2 times I changed it I coulda swore I did it before; and I checked it the time before posting this after I saved it; I saved, closed then loaded the ROM, and it saved.... but the next day it was back and I knew.
Posted: Mon Feb 25, 2008 4:19 pm
if u tested this on 0.0.2.1r2 t1 and it works good post here so i can close
