Copy/Paste bugs:
Copy/Paste bugs:
first off, I noticed the latest info about the version in the forum is for r6 as seen in the sticky =) Second, here is the .txt document I wrote earlier: Funny bug, the copy/paste bug. Using Ver 0.0.2.0r7 On alot of the tables in the parameters window the different option tabs are having trouble with \"CTRL+C\" otherwise known as copy, and the paste shortcut as well. All of these fields/panes are displaying these traits: EBC Duty Cycle Lookup Map->target duty cycle fields... Electronic Boost Controller Settings->Target TPS boost Multiplier Duty Compensation maps Gear Based Target Maps RPM based target maps MIL Shiftlight All 3 output controls, didn't look at adjustments but I would imagine they will react the same These ones will not allow you to paste, but you can copy and the contents never make it to the clipboard. The field's value (if continue is clicked) is replaced with a 'v': Rom Comments ECT Overheat Protection->ECT field Secondary Map Settings->Condition based fields 3step - Launch Control Settings 3step - Anti-Lag 3step - Full Throttle Shift Settings Moving on; Just figured it out... CTRL+C and CTRL+V are not seeming to be bound to the cut/paste commands in the parameter window, but right click+copy/paste works just fine.. I have a touchpad, so keyboard shortcuts help alot. If you need the trouble code info, I can post it, but it should be reproducable on your end if not fixed in the 0.0.2.1 version...
copy pas doesn't work in parameters that is the bug right? text box copy should work at all time
calvin wrote:copy pas doesn't work in parameters that is the bug right? text box copy should work at all time
Yeah, go to almost any field/table and try to CTRL+C or CTRL+V to copy and paste; on most it is an instantaneous fault with CTRL+C, some only pasting causes the bug, but copying the info doesn't ever get the info to the clipboard. If you right click, then choose copy or paste, it works fine. Just the copy/paste shortcuts are bad in the parameters window.
