map tracer lockup
Posted: Wed Mar 12, 2008 12:28 am
I have just started using r7 and found that while tracing maps during a live tune the tracer will lock while switching from low to high maps. I have reproduced this error a few times. Logging still works fine however the tracer freezes on the low cam map just before cross over. This only happens when follow vtec and follow map is enabled. Also I noticed if you set the tracer on quad it does not freeze. Also, once a single tracer does freeze you can set it to quad to un freeze it. I saw this posted further down but the topic is locked.
