Trace jumping to Last column during deaccel: IMPORTANT:
i just release a test update. Send me a mail i'll give u beta version tooo
yes in current (not new expiry release) I am seeing the bug where you can't lower or change the col1 mbar value; goes back to previous setting... not low enough to avoid the error. (new tune)
r9 correct? That is fixed in r11 being released today. r11 will only popup onces this msg. It will also ask to lower the mBar of column 1.
Correct r9. Thanks!
b20vtechb
Post by b20vtechb »
so this will be fixed in the update tommorow? i too noticed the colum changing to b1 and not being edited in mbar like it should be.
2kCivicSi
Post by 2kCivicSi »
Question.. in my non-boosted B16, the last column is set to 1024. With the cold temps and high baro, I am reading a WOT map pressure of about 1050... and ECTune only hilights two cells in the last column instead of 4 cells.. Could this cause a similar problem to what you guys are talking about with the lower bounds?
Go to the fuel table parameters and change the number of columns to 11. I have seen this also with a good working ram air! This way you get the first boost column on screen. Thats were your other 2 cells are reading.
Gaskleppie wrote:Go to the fuel table parameters and change the number of columns to 11. I have seen this also with a good working ram air! This way you get the first boost column on screen. Thats were your other 2 cells are reading.
thanks
