JIT Debugger?/Ostrich Problems Solved
				S.R.Rudeboy
I am trying to get Ectune to connect to my Ostrich, but every time i click on ostrich info, I get an error message saying cant detect \"ostrichECT\" on port ; com6... But on the bottom left corner it will say connected..Then im getting 2 errors..If I could figure out how to turn JIT Debugger on, or get another config file with it in there that would be great..... I copied and pasted the two error messages below  ************* Exception Text **************  System.NullReferenceException: Object reference not set to an instance of an object.     at eCtune.Dal.Emulator.CheckEmulator(Boolean reportError)     at eCtune.frmOstrichInfo.†š‹Š“™‡��()     at eCtune.frmOstrichInfo.�†‘‰™Ž†“–(Object , EventArgs )     at System.Windows.Forms.Form.OnLoad(EventArgs e)     at System.Windows.Forms.Form.OnCreateControl()     at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)     at System.Windows.Forms.Control.CreateControl()     at System.Windows.Forms.Control.WmShowWindow(Message& m)     at System.Windows.Forms.Control.WndProc(Message& m)     at System.Windows.Forms.ScrollableControl.WndProc(Message& m)     at System.Windows.Forms.ContainerControl.WndProc(Message& m)     at System.Windows.Forms.Form.WmShowWindow(Message& m)     at System.Windows.Forms.Form.WndProc(Message& m)     at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)     at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)     at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)    The second one is:    ************** Exception Text **************  System.InvalidOperationException: Collection was modified; enumeration operation may not execute.     at System.Collections.ArrayList.ArrayListEnumeratorSimple.MoveNext()     at System.Windows.Forms.Application.ExitInternal()     at System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t)     at System.Windows.Forms.Control.WndProcException(Exception e)     at System.Windows.Forms.Control.ControlNativeWindow.OnThreadException(Exception e)     at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)     at System.Windows.Forms.SafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow)     at System.Windows.Forms.Control.SetVisibleCore(Boolean value)     at System.Windows.Forms.Form.SetVisibleCore(Boolean value)     at System.Windows.Forms.Control.set_Visible(Boolean value)     at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)     at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)     at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)     at System.Windows.Forms.Form.ShowDialog()     at eCtune.FrmMain.��“Š˜™‹†‹™(Object , EventArgs )     at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)     at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)     at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)     at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)     at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)     at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)     at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)     at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)     at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)     at System.Windows.Forms.Control.WndProc(Message& m)     at System.Windows.Forms.ScrollableControl.WndProc(Message& m)     at System.Windows.Forms.ToolStrip.WndProc(Message& m)     at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)     at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
				S.R.Rudeboy
				S.R.Rudeboy
I have tried to force update, it does update, but no luck with emulator...I d-loaded VB2008 for the JIT debugger, but im not very computer literate, so im not too sure how to utilize it....Im sure i seem like a real dumbass cause i cant make my emu work, i just never had a prob with any other editor..I tried to continue when the exception happens, when i press get license i get an error message saying \"Error get Serial\"
						- nate
Installing the debugger won't help anything.     Try going to add/remove programs and uninstalling eCtune. Also while you are there make sure you have .Net Framework Versions 2.0 and 3.0 installed.    Then download the latest version of eCtune from here: http://websrv.ectune.com/ectune.setup.current.rar    Install it, then run the force update, then start eCtune    Se if that clears up your problem...
				S.R.Rudeboy
				S.R.Rudeboy
OCX is has nothing to do with emulator.    Post you step how you fixed it.    .Net Framework 2.0  .Net Framework 3.0  .Net Framework 3.5
									Regards,  eCtune Team  eCtune Authorized Tuner  Location: Caribbean & Suriname    aim:calvinPGMFI  skype:ectune    We remote connect to your laptop if you have problems. Best support in the world.
				S.R.Rudeboy
I went from Framework 1.1 to 2.0 to 3.0 to 3.5...now when i try to install the newest driver from FTDI, my pc crashes...i kno the ocx file has nothing to do with the emulator, but it asks for the ocx file IF you dont have it already..
 ...if one of you admins want to remote my desktop to see if you can solve the problem, be my guest...Id rather you guys try so you can see the problem im having
If pc crashed from the newest FTDI driver you have a big problem.  I'm online now for an other so i can support hit me on AIM/MSN
				S.R.Rudeboy
