Map Creation - GSR Cams and Prec. 650 Inj.
timmydogg
Post by timmydogg »
I have a b16 bored 81.50mm and plan to use GSR cams. When creating the base map, I assume I will select JDM P30 for ECU type (ECU is a PR3-JO1-205), but what should I use for the timing and fuel base? P72 because of cams and slight overbore? Also, does anyone know which Injector Battery Offset best matches the Precision 650cc Hi Imp. injectors? These are fairly new as far as I know. Part Number: 042-0651 Flow Rate: 650CC Impendance: High 12Ω Opening (ms): 1.140 Closing (ms): 0.850 Nozzle Style: Disc Thanks in advance for the help, Tim
wrong forum. moving
timmydogg
Post by timmydogg »
sorry about that... :oops:
Just select a 203 b16 map and work from there... There should be batter tables for your injectors
timmydogg
Post by timmydogg »
Thanks Calvin! I'm a little ahead of the game. I waiting for my ostrich to get here so I can register and play with software. I had bought Crome Pro already and remember my injectors were not in there, so I figured I would ask. This is my first time and i'm scared!!! :shock: hahahahaha
you can download and install the software already. If you paid besure the use your paypal email address when registering
timmydogg
Post by timmydogg »
Sounds good. Actually bought eCtune and Ostrich from xenocron. I'll get it installed tonight and play around a bit. Thanks again!
timmydogg
injectors not listed
Post by timmydogg »
Actually my injectors are not listed. I'm assuming the prec. 525 hi imp. injectors would be similar to their 650 hi imp. injectors? am i wrong? the only other choice is the prec. 680 low imp.
u can tweak it your self too
