Ok, so i just got everything setup. Did my ectune update, did my ostrich update, updated my usb ports. Everything is working and I've loaded a basemap however the datalogger won't connect. popup says can't connect to ecu.
make sure j12 is cut. Check in device manager which port your datalogging uses.(don't plug in your ostrich). Now that you have the right comm port open settings->datalogging Disable auto-scan Select correct comm port Baud 38400 And press test
OneRM wrote:Ok, so i just got everything setup. Did my ectune update, did my ostrich update, updated my usb ports. Everything is working and I've loaded a basemap however the datalogger won't connect. popup says can't connect to ecu.
yup, did you turn your key on when you were trying to connect?
hard set the comm port and the baud should be 38400
If you have uploaded a basemap when you put the key in the on position your CEL will light then go out, this is where you need to pay attention, the CEL will flash again shortly after the CEL goes out.
Pay close attention what u see and hear if u key on. And let me know. Did you do upload base+calibration?
