Page 1 of 4
questions about autotune
Posted: Mon May 05, 2008 4:50 am
by cquence
ok I was trying to find more info about when can I use autotune and when not to. Obviously I wont be using it to tune the boosted parts of my maps.. But can I use it to fine tune my medium to high load NON-boosted maps? What about while in vtec? thanks
Posted: Mon May 05, 2008 9:16 am
there is no auto-tune. u just have to log, select a part of the map, and auto adjust.
Posted: Mon May 05, 2008 9:49 am
by cquence
Oh.. i thought autoadjust is same as autotune.. never mind.. OK so do it manually then by selecting a portion of the map. I love how the selected portion of the disappear after each auto-adjust. It makes it easy to know which ones have been already adjusted..
Posted: Mon May 05, 2008 10:09 am
you can lock an area too so it doesn't record in overlay anymore
Posted: Tue May 06, 2008 12:28 am
Calvin, I searched everywhere for an \"unlock button\" is there one?
Posted: Tue May 06, 2008 12:29 am
Same button you lock with
Posted: Tue May 06, 2008 12:34 am
ok... me just reading lock took it literally ;) Thanks! I finally got those $%@#$ cells unlocked... lol.
Posted: Tue May 06, 2008 12:38 pm
by crx303
Auto adjust caused my maps to look like a mess, so I started all over again. Did I do something wrong?
Posted: Tue May 06, 2008 3:45 pm
probally. U all did it your self. You click adj. What it doesn't Stored afr per cell Filter stored afr per cell Target afr per cell that gives a % change to the able then % * p(0.75 default) then table * (%*P). So either your target afr was wrong or your lambda recording goes wrong. It's just math that reacts to the data and function(a user defines)
Posted: Thu May 08, 2008 6:19 pm
by crx303
I'll try again ;)
Posted: Sun May 11, 2008 4:24 am
by TopMountGSR
say you have cells like: 10% 7% 16% 12% and you highlight them all and click the auto adjust button does it adjust each of them individually or an average adjust? does that make sense? auto tune would be cool for the partial throttle area..
Posted: Sun May 11, 2008 9:10 am
it take an avg. and adjust the maps
Posted: Sun May 11, 2008 3:23 pm
by TopMountGSR
ok so it would probably be better to highlight them individually then auto adjust them
Posted: Sun May 11, 2008 4:25 pm
I normally do i groups of 4 cell. If u do each cell it will make your map damm ugly.
Posted: Sun May 11, 2008 10:32 pm
by TopMountGSR
haha my maps are already damn ugly ;) but they seem to work. I guess I have a lot to learn thanks for your help
