Overflow Happen on Table Lookup Error message.
trooper
Post by trooper »
has any one expeiranced this message? it seems to happen when at high rpm let off no throttle ot down shifting while still in gear? Could it be possable that the map sensor scalling is off and the vaccume is going past coloumn 1? \"Overflow Happen on Table Look up. Possiable cause mbar is lower then mbar coloumn 1 please verify in datalog. please lower the mbar in column1.\"
Isn't the msg clear? that your current mbar was lower then the mbar in the first column? Causing an overflow condition. It's be explained quite a few times on forum. Find in your datalog what your lowest mbar is during decel. And set the first column a little lower then that.
relic1
Post by relic1 »
calvin wrote:Isn't the msg clear? that your current mbar was lower then the mbar in the first column? Causing an overflow condition. It's be explained quite a few times on forum. Find in your datalog what your lowest mbar is during decel. And set the first column a little lower then that.
first to post about an all ready answered question. Best support ever. :D OP: it's an intended function, if it wasn't there things would go wacky. BTW I found this after pressing search and typing in overflow. (I hate it when people do this, but it was too easy to find to not mention it) http://forum.ectune.com/viewtopic.php?t ... t=overflow
trooper
Post by trooper »
yes the message is clear now, i was just looking for some verification.
sloshy
Post by sloshy »
lol funny things is this what i was searching for, i had my afr and timing down pretty good as far as i could tell and then BAM!! the popup i was worried so i stopped and log in here to research..
