Timing, disable.
gijs
Timing, disable.
Post by gijs »
Disabling the ignition under boost, what happens then? And how does it compare to the ignition table, should I compensate and by how much?
It disables all ign correction.. The ones enabled are: IAT ECT Cylinder GPO's Anti-lag tps tipin ign disable and various other honda ign corrections
gijs
Post by gijs »
Ok and is it recommended under boost conditions. ? And should I add or pull timing when I disable?
you shouldn't add or remove timing. Disable in boost yes
