Newly Installed eCtune with Vista
Hello, First of all, thanks for the great deal on the Pro version! I got my registration string and pasted the xml file under the ectune directory. I made a basemap and see the base map. It seems to me that the fuel map is not right (with a reg x)? Granted, this is a Visa CHINESE - may have something to do with it. I will install eCtune on a English Vista if this is the case. Thanks for the help! Derek
- ectune1.jpg (155.95 KiB) Viewed 5689 times
i don't know and i'm not installing Chinese vista to test... Not everybody has that problem... you don't get an error first?
LOL! I thought so! Thanks for the reply Calvin! I will most likely get it installed on a English XP instead! Would the license.xml work on another laptop or would I need to send in the registration request again? For kicks and grins - here's the error message that was listed.. I believe it has something with \"JIT\" Some Chinese too.. lol! 如需叫用 Just-In-Time (JIT) 偵錯的詳細資料, 請參閱本訊息結尾處 (而非這個對話方塊) 的資訊。 ************** 例外狀況文字 ************** System.NullReferenceException: 並未將物件參考設定為物件的執行個體 於 e’8f1rd1Œq†l•Ÿv˜tž.685kftcv7ž–2et–Šj›.•˜š‡‡‹Â�˜–•() 於 e’8f1rd1Œq†l•Ÿv˜tž.685kftcv7ž–2et–Šj›.OnPaint(PaintEventArgs ) 於 System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) 於 System.Windows.Forms.Control.WmPaint(Message& m) 於 System.Windows.Forms.Control.WndProc(Message& m) 於 System.Windows.Forms.ScrollableControl.WndProc(Message& m) 於 System.Windows.Forms.ContainerControl.WndProc(Message& m) 於 System.Windows.Forms.UserControl.WndProc(Message& m) 於 System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) 於 System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) 於 System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** 已載入的組件 ************** mscorlib 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- eCtune 組件版本: 0.0.2.1 Win32 版本: 0.0.2.1 程式碼基底: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- startup_lib_net_2_0 組件版本: 2.0.0.0 Win32 版本: 0.0.2.1 程式碼基底: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System.Xml 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- mscorlib.resources 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- System.Management 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- System.Windows.Forms.resources 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_zh-CHT_b77a5c561934e089/System.Windows.Forms.resources.dll ---------------------------------------- Accessibility 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Configuration 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Security 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System.Security/2.0.0.0__b03f5f7f11d50a3a/System.Security.dll ---------------------------------------- System.Web.Services 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll ---------------------------------------- System.Deployment 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll ---------------------------------------- System.Deployment.resources 組件版本: 2.0.0.0 Win32 版本: 2.0.50727.1433 (REDBITS.050727-1400) 程式碼基底: file:///C:/Windows/assembly/GAC_MSIL/System.Deployment.resources/2.0.0.0_zh-CHT_b03f5f7f11d50a3a/System.Deployment.resources.dll ---------------------------------------- Interop.MTSSDKLib 組件版本: 1.0.0.0 Win32 版本: 1.0.0.0 程式碼基底: file:///C:/Program%20Files/eCtune/Interop.MTSSDKLib.DLL ---------------------------------------- eCtune.XmlSerializers 組件版本: 0.0.2.1 Win32 版本: 0.0.2.1 程式碼基底: file:///C:/Program%20Files/eCtune/eCtune.XmlSerializers.DLL
On my company HP, the same license file worked in both XP and Vista (bootmagic). Exact same setup on my own T61 - required a different license. Same exact bootmagic setup for dualboot, so I´m not so sure what caused this. The big red X etc. I have seen before. At that time, it was related to .NET . If I removed ALL .NET components and versions and updates, then re-installed eCtune, the installer would get the right .NET stuff, install it and everything worked again. As for Vista - when ever in doubt, try to disable UAC. This seems to solve most of the annoying issues with Vista. Sad but true. /Allan
- Civic Tsi
Got the X bug. I just had a new .cal opened and it was showing the low cam fuel table. 1. Click the fuel table to make it active. 2. Press F4, you should have a view in % of the fuel table 3. Press F8 to switch to high cam 4. Press F7 to go back to low cam (boom)
