eCtune & Vista Crash
janvitos
Post by janvitos »
Hi. I just got eCtune PRO version with a valid license. However, when i try to run the program, i get the following error :
Method not found: 'Void System.GC.Collect(Int32, System.GCCollectionMode)'. Details -> See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.MissingMethodException: Method not found: 'Void System.GC.Collect(Int32, System.GCCollectionMode)'. at 0ž�87˜Œ›�i˜stžs›sˆ�.�œž81kŒšgfebšyodvžn.›�•‡‰–Œ‰›(Object , EventArgs ) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
No. 1 thing to do is: Disable UAC in vista. Otherwise it will mess up all sorts of file copy actions when you upgrade, copy in the license etc. See http://forum.ectune.com/viewtopic.php?t=643 /Allan
janvitos
Post by janvitos »
UAC is already disabled ; I always hated it since Vista came out. So what would be the next thing to do ?
did you install .net? What point did it hang? Did you follow all the vista notes? Run as administrator, copy files to root before eCtune directory; force update, etc?
msg shows that .net 3.5 is not installed
Thought you made an check on the availability of .NET on the install Calvin?
me thought so tooo. i check for the folder but that doesn't mean the 3.5 works good
Checked on an XP with no 3.5 installed and eCtune nicely installs it. And that pc has an really messed up XP install :lol:
setup file?
Sorry?
