Closed Loop begins too early
- Synoptic
narrow, closed loop. Stock O2, etc.. I never used Wideband Closed loop except for my own car.Gaskleppie wrote:Is this with narrow of wide band closed loop?
- Synoptic
Ok. Last cars that came in had bad O2 sensor or simply no O2 sensor at all
But, I was told by a customer that it was not bad as before, but it still did the thing. My car is still broken. I have a car to tune today. Will see how it goes today.
![Sad :(](./images/smilies/icon_sad.gif)
- Synoptic
FYI, I never saw a problem with cold start, ebcause of the minimum ECT for closed loop that is at 81Celcius. I tested today, didint have a problem. Brand New NTK o2 sensor, but the sensor never gave the 3.88 volt. is it because of the patch for wideband that has been removed ? It seemed to work perfectly though.Gaskleppie wrote:I tested 0.0.41 Closed loop with narrowband is like stock on my own car. I tested several times warm start but the closed loop always started late. When the car starts cold, it stays open loop till you start driving or when you press the pedal a few times. Looks stock to me.
pathc is still there but not the patch that turn the closeloop on full time:)... So wideband doesn't work yet but all the 1.5v checks(removed when wideband) are still there
