will not connect to ecu
fireztorm
i have ostrich 2.0 and hulog extreme with updated firmware and newest ectune pro i can connect to the ostrich and upload map but it wont communicate to the ecu i do not see the mil light flash 3 times and my datalogging does not work at all. ideas?
then there is a problem between ostrich and ecu. what color is the connect when you are connected to emulator? did you put the ostrich cable properly in the ecu?
- Garrett
when uploading the first time upload base rom & cal and verify it
real time update is enabled. it verifies correctly, the emualtor works fine, i can load a map into the emulator and download it to the laptop later. but the mil light should give 3 flashes when i have loaded a basemap & calibration to the emulator right? in this case it do not flash, just the regular flash when i hear the fuel pump.
- Garrett
are you sure that de jumper J1 in the ecu is ON? is you remove the ostrich, the car start?
