will not connect to ecu
Garrett
Post by Garrett »
Is the car start without ostrich J1 is not there
fireztorm
Post by fireztorm »
what do you mean?
Garrett
Post by Garrett »
When J1 is ON (with a jumper) the ecu use the ROM in the socket not in the OKI if J1 is OFF(without a jumper) the ecu use the ROM IN the OKI
fireztorm
Post by fireztorm »
ok, then i guess its there, because i havent done anyting to the j1.
Garrett
Post by Garrett »
fireztorm wrote:ok, then i guess its there, because i havent done anyting to the j1.
take a look at
fireztorm
Post by fireztorm »
what type ecu is on the picture? usdm?
fireztorm
Post by fireztorm »
ok, i found the J1 it is without a jumper..
Garrett
Post by Garrett »
install a jumper and welcome in eCtune world :twisted:
Theres your problem, simple enough. Just add the jumper back in and enjoy eCtune.
Garrett wrote:install a jumper and welcome in eCtune world :twisted:
Haha, beat me to it!
fireztorm
Post by fireztorm »
nice! :D i will try that first ting in the morning.. tired now.. but why havent i been informed to this before? i have read the troubleshooting guide.. and how to install the ostrich on moates.net. but i havent heard about this before..
When an ecu is chipped, it is assumed that the jumper is installed. By not having the jumper, you are are running off the factory settings so technically, you are not chipped.
fireztorm
Post by fireztorm »
ok, but i still have problems with my datalogging. or does this fix that to? it tells me that i cannot connect to the ecu. i have cut j12 and im running a hulog extreme. what can be wrong here?
It shoudl all be fixed once your running eCtune.
fireztorm
Post by fireztorm »
ok, thanks! :) i will try tomorrow.
