I am using R15. well it works now. I usually change a selection and hit the TAB key. But with the minimal speed setting if you click off the selection after you make a change it stays to what you have changed it too. If you hit TAB it goes back to 10mph.
Has anyone tried the Fuel Correction by gear? I noticed the in Sensor display window there is Fuel Correction of +2 But I was in neutral and it should not be effective till 15mph in first gear.
I use the gear fuel correction.. I think I use -2 in 4th and -3 in 5th. It helps equal out my air fuel ratios thoughout my gears under boost. Before I did this I noticed that I was running around 11.8s in 3rd, then 11.3's in 4th, and sometimes 10.9s in 5th... Or something like that, the gear corrections did help out. Hope this helps. dk
