excuse my math skills
james25
Post by james25 »
how do you say/write .003 .0003 .0035 Geezz, math is my downfall
.003 Three Thousandths .0003 Three \"Ten-thousandths\" .0035 Three and a half thousandths .05 is \"Five Hundredths\" .1 Tenths .01 Hundredth .001 Thousandth .0001 Ten-Thousandth .00001 Hundred-Thousandth .000001 Millionth All \"Of an inch\" of-course.
JaredKaragen wrote:.003 Three Thousandths .0003 Three "Ten-thousandths" .0035 Three and a half thousandths .05 is "Five Hundredths" .1 Tenths .01 Hundredth .001 Thousandth .0001 Ten-Thousandth .00001 Hundred-Thousandth .000001 Millionth All "Of an inch" of-course.
Also known as 35 ten-thousandths. Just in case you ever hear it said that way. Same thing, different way to say it. Simple FYI for the OP.
Yeah The proper way to say it is that, but I had a major brain fart at that moment... ;)
Orthello
Post by Orthello »
.001 milli .000001 micro So 1 mm = 0.001 meter etc. milli = 10^-3 micro = 10^-6 nano = 10^-9 pico = 10^-12 8)
james25
Post by james25 »
Thanks for the replys guys! I knew I should have listened to my math teacher a long time ago. But this is a good refresher!
combz
Post by combz »
this may be taking it too far.. but say you wanted to know how many Ten-thousandths (0.0001), were in 3 thousandths (0.003) you can do 0.003= 3 * something * (1 * 0.0001) which in words is three thousandths is equal to three multiplied by some numbers of ten-thousandths to figure it out an easy way is to convert everything to sceientific notation..e.g- 0.1= 1 * 10^-1, 0.01=10^-2, 0.003 = 3 * 10^-3, and so on so you have 3* 10^-3= (3*10^x) * (1 * 10^-4) so now all you really do is say how to you get -3 (the exponent on the right side) to be equal to the exponent on the right side...e.i what should x be. Well if you recall when multiplying values with the same bases (10's in this case), you can add the exponenents. so -3=X+ (-4) solve for X -3+4=X 1=X X=1 check -3=(1)+(-4) -3=-3 then you go back and you know that your X=1, so 3* 10^-3= 3* 10^(1) *(1 * 10^-4) which is 0.003= 30 * 0.0001 in english three thousandth is equal to 30 ten-thousandths This method can be applied to all numbers ofcourse.. Too much info eh.. I doubt anyone will read that :(
combz
Post by combz »
jared you are correct too 0.0035 can be read as three and one half thousandths or 3.5 thousandths applying to what i said above because 0.0035= 3.5 thousandths since, 0.0035= 3.5 * (10^-3) remember 10^-3 is read as thousandths so 3.5 thousandths= 3.5 times one thousandth which is 3.5 thousandths= 3.5 thousandths
Orthello
Post by Orthello »
How to make a simple question complicated 8)
Orthello wrote:How to make a simple question complicated 8)
Yeah this was taken way too far lol.
james25
Post by james25 »
Simple to combz equations, you guys rock! :lol: I just wanted to make sure I say the right measurements when I take my parts to a machine shop and not sound like an ass :D have to be able to speak machine shop language.
combz
Post by combz »
combz wrote:this may be taking it too far..
i warned .. lol i would have orginally explained the way that was first posted...but for those wanting more..i couldnt resist.. I am a high school math teacher as well as a computer scientist :P
combz wrote:this may be taking it too far.. but say you wanted to know how many Ten-thousandths (0.0001), were in 3 thousandths (0.003) you can do 0.003= 3 * something * (1 * 0.0001) which in words is three thousandths is equal to three multiplied by some numbers of ten-thousandths to figure it out an easy way is to convert everything to sceientific notation..e.g- 0.1= 1 * 10^-1, 0.01=10^-2, 0.003 = 3 * 10^-3, and so on so you have 3* 10^-3= (3*10^x) * (1 * 10^-4) so now all you really do is say how to you get -3 (the exponent on the right side) to be equal to the exponent on the right side...e.i what should x be. Well if you recall when multiplying values with the same bases (10's in this case), you can add the exponenents. so -3=X+ (-4) solve for X -3+4=X 1=X X=1 check -3=(1)+(-4) -3=-3 then you go back and you know that your X=1, so 3* 10^-3= 3* 10^(1) *(1 * 10^-4) which is 0.003= 30 * 0.0001 in english three thousandth is equal to 30 ten-thousandths This method can be applied to all numbers ofcourse.. Too much info eh.. I doubt anyone will read that :(
You just had to spell it out both ways eh?? lolz
