The progression of an H22
rschoener
I agree if you use the correct cleareance bearing the is the most important thing. I know that most places that sell ACL or other aftermarket bearing sell the Standard sets to everyone. Alot of people just throw them in everything. I have seen big name places use standard bearings for everything they build.
greasemonkee
Seems the bearing is just disintegrated. Nothing is disassembled so I havent looked at anything else closely. ACL STD bearings, 55mm mains The motor was broken in with shit 5w-30 from the local parts store, $1.49 a qt I think. Filled, started...run for 10 minutes and drained and new oil filter. Then it was immediately put on the dyno and tuned to 10psi. Drove around easy for a while working out other bugs. 2 passes at the track, oil changed again and then put in the Eneos 0W-50 and the K&N Oil Filter...couple more passes on the dyno and 3 at the track...gonerschoener wrote:Does it look like the Bearing spun or was it just mashed? How are the other Rod Bearings. Oh and were they OEM honda or ACL? Oil what do you run? Just would like to know. I like to study the mechanical failuers. I have had great luck with Royal purple or Moblie 1 10-30 and we always use Honda Bearings.
I definitely will...but I got busy with this today, so the H might move down in priority for a little bit
- k-before.JPG (322.06 KiB) Viewed 14541 times
- k-after.JPG (323.13 KiB) Viewed 14541 times
- g.t engineering
#4 Spun, #1 was about to spin but didnt. #4 Rod has a LOT of wrist pin play for some reason...not sure what that's about. Bearing Pics: (click on the image for large version) Bearings #1 - #4 all lined up nice and pretty
Bearing #4
Bearing #3
Bearing #2
Bearing #1
#1 - Weird Gap thing going on here
Mains all looked fine...some of the original coating was on each of the mains.
Bearing #4
Bearing #3
Bearing #2
Bearing #1
Mains all looked fine...some of the original coating was on each of the mains.Regards, Xenocron Tuning Solutions eCtune Team eCtune Authorized Tuner Location: Ringwood, NJ / Hillburn, NY U.S.A. www.xenocron.com DIY ECU Chipping, Fuel Management Parts and more...
are those pits in the #3 bearing? hard to tell from the pictures. what kind and weight oil do you use? They all look a bit too shiny, suggesting that oiling/heat was a problem. But it doesnt make sense that your mains are perfect.
No pits in the bearings...#1/#4 are \"smashed\" I'd say...#2/#3 look fine except for some grooves where bearing material probably got in and wore away a groove. The smashing is at an angle though which is odd to me...why there would be more pressure on one side of the bearing than the other, unless maybe the crank is bent/warped...i unno. Taking the head off today I think.
happen to check the plugs for inaudible det? makes a little sense to me that the sides have more wear since the rod/crank angle at peak cylinder pressure is not on top and bottom of the bearing, but more so to the sides of the bearing.
Plugs read clean on the dyno and I was completely conservative on the timing...plugs checked after the first two runs where everything was fine read fine as well. I dont have any logs of the runs unfortunately because the power plug on my wideband was loose which would cause eCtune to stumble and quit datalogging right at the launch. That got annoying...I need to find a better power cable I guess. BTW, the oil was Eneos 0W-50 if I didnt mention that before.
- g.t engineering
Got a squeeky clean A4 crank from Reid @ Kaizenspeed (thanks for the hook-up) and the Pauter rods are being sent off tomorrow to be reconditioned at Pauter tomorrow
mike_belben
now THAT i can make some power withxenocron wrote:I definitely will...but I got busy with this today, so the H might move down in priority for a little bit
