weird idle issue
weird idle issue
I am having a terrable idle problem...It will pop,buck go lean the rich ect... so far I have cut alt c,disable eld,tuned battery offsets the best i could,ect,iat ect..... even when I rev and hold it while sitting say 4000 rpm it will does this. my mid and top is perfect runs like a champ..... I am starting to think it is something with the car My set up is precision 880s (new) walbrogh pump 255 obx fuel rail mangafuel fpr (the boost one no vaccum only boost on charge pipe) msd ignition I am a licensed tech and this one has me stumped.. I have addresed every isue I could think of... any ideas would be apreciated
Aem uego, its not the wideband it is accurate we used my friends plx aswell just in case it was off but it was the same reading........I am posting my cal needs a bit more tweaking but it is the best I can get it to idle. Please check if you can, im pretty sure its the car but I might have missed something
- mine2.cal
- (8.17 KiB) Downloaded 385 times
heres my datalog at idle have a look for me.... its rich as hell but thats the only way I could get it idle decent .....Thanks guys
- shawndatalog.elf
- (999.75 KiB) Downloaded 419 times
Re: weird idle issue
Huh?sj-performance wrote: mangafuel fpr (the boost one no vaccum only boost on charge pipe)
Yes I know I thought it was weird to.... I called magnafuel and they said that regulator is only supposed to see boost and not vaccum off the charge pipe....anyways I put my stock rail,regulator and lines on tonight it was beter but when it gets warm it goes to shit when its cool I can idle it in the 14s???atleast now I can idle 13.0 afr when its warm.
