How much blow-by is too much?
I am new to Hondas so I am not sure but my car has quite a bit of crank case pressure. At idle I have a steady stream of light bluish smoke coming from my 2 valve cover vent hose. Is that a sign of badness happening inside? I have checked plugs and all 4 are extremely consistent so I would think that it would not be a single bad cyl, and I had the head off recently and everything looked great inside plus I put the head back on completely rebuilt.
If you want to expand your engine life, make a crank ventilation system that is big enough. Like mine:
the can is not ready yet and its upside down. It works very good. I lowered the oil use of my old stock B16 on trackdays with almost half! I use a plastic old oil can at this moment.
Its always better when you have no blow-by but when you have it, its better to let it out the easiest way possible. the big advantage of this system are the oversized hoses. Thick hoses reduce the air/oil speed inside the hoses and it gives the oil a better chance to drain back to the engine instead of blowing away.So the blow-by I am seeing isnt a sign of a problem?
Tired dohc vtec motors are known to burn oil, since it sucks oil through the rings, burns it, and some in turn is pushed back through the rings as smoke. Although Honda uses low tension rings, that amount of blowby is somewhat excessive. My D15B2 beater blows a good deal of air from the breather at idle (no smoke though), and still gets 40mpg and burns no oil. Catch cans will help, and in more than one way. The PCV valve could start feeding that messy air to the motor, which will clog up valves, and possibly cause detonation in severe conditions.
