a/t disable code didn't work.
butch11a
i just installed an a/t p28 ecu on my car to be able to use boost control, installed everything and got a cel when i started it, i knew that would happen since it was an a/t box, but i thought i could disable the code through parameters setting, disable a/t check box, tried it several times, still the cel...i'll just remove the resistors then, this is just to let Calvin know... this was just after running the upgrade....
Removed r17 and jumpered r18 and still got a cel, a code 30 something about the a/t, i forgot to add, i started before on a jdm p72 rom manual, took out the ostrich and installed it on the a/t p27, should i change the rom or something during rom creation to select the new ecu type? tried clearing the cel but it would still come back, turn off engine, clear cel and once the engine starts after a second the cel comes back again...
