MIL CHECK
Synoptic
MIL CHECK
Post by Synoptic »
I have set the MIL check to use B5 : works fine. I then go in the parameter and put it to KOEO. Upload cal to ostrich (based on 0.38 from the last email calvin). turn Key OFF, then Key ON. the Check MIL is still using B5. My B5 pin is GND by default (using a switch) so when the ECU boots up, it sees B5 input and seems to ignore the fact that I want to use the TPS instead. If I remove GND from B5 THEN I can use the TPS to check for code. I would like to be able to use more than 1 input to check code.
so it uses both? Weird... -Clean Cal -Put to KOEO only then upload everything... Turn off ecu -Turn on.. -Check if TPS works. I'll double check that piece of the code again. I didn't notice that yesterday when testing... Please look in datalogging data list there is data labeled \"SCC-Routine\" Check what happen with that checkbox if you gnd B5 and use KOEO TPS
Synoptic
Post by Synoptic »
calvin wrote:so it uses both? Weird... -Clean Cal -Put to KOEO only then upload everything... Turn off ecu -Turn on.. -Check if TPS works. I'll double check that piece of the code again. I didn't notice that yesterday when testing... Please look in datalogging data list there is data labeled "SCC-Routine" Check what happen with that checkbox if you gnd B5 and use KOEO TPS
Ok, will do later this week, unless someone else wants to try, i wont go to the shop for a couple of days now..
can you send me the calibration. I think it has to do with your gps thing(input output)
fixed all KOEO bugs
