datalogger not recording AFR
SpoolinSol
Finally decided to start tuning AFR for much higher boost on the new engine. I go out datalogging and doing pulls in the morning and when I hit 'record' it starts filling in cells for low cam, but wouldn't fill in values for hi cam. I go home, think I figured out that I actually had vtec disabled, so I set the crossover RPM and go out to datalog some more. Now when I press 'record' the timer will start, and all of my real time values/AFRs will be displayed but my cells won't record any values. I wasn't looking at the laptop for a while, just driving around, and then I looked and it had filled in some cells, but then stopped recording. Usually I will have someone else drive and make a few pulls, I'll adjust the map, clear my cells, hit record again, repeat. But now it will only randomly fill in cells for a short time, then won't record anymore. Anyone know what I'm doing wrong?
SpoolinSol
SpoolinSol
SpoolinSol
it was only recording to the overlay over a certain ECT value? could be my issue since my car runs cold as hell with the 2" aluminum radiator...kyhatch01 wrote:i had a prob like that it was my gear settings and ect temp setting my car did not run that hot so i lowered the temp and bang good as new hope this helps
yeah, you shouldn't tune unless the engine reaches operating temp though; try to heat it up before driving... do you have a thermostat in the car? worse comes to worse you will need to turn down the ECT requirement, but I believe the tune won't be as on as it should be if you have to do that.SpoolinSol wrote:it was only recording to the overlay over a certain ECT value? could be my issue since my car runs cold as hell with the 2" aluminum radiator...kyhatch01 wrote:i had a prob like that it was my gear settings and ect temp setting my car did not run that hot so i lowered the temp and bang good as new hope this helps
SpoolinSol
yea, it has a thermostat, but this damn 2" aluminum radiator and coolllldddd michigan weather make this thing get colder and colder the more I run it haha. I'd rather do 4th gear pulls and get 'too much' airflow to the rad than do 3rd gear pulls and not get as good of a log. I checked my Overlay AFR settings and it was at 174-282, so I'll try adjusting the ECT settings next time I get a wideband on it, thx guysJaredKaragen wrote:yeah, you shouldn't tune unless the engine reaches operating temp though; try to heat it up before driving... do you have a thermostat in the car? worse comes to worse you will need to turn down the ECT requirement, but I believe the tune won't be as on as it should be if you have to do that.SpoolinSol wrote:it was only recording to the overlay over a certain ECT value? could be my issue since my car runs cold as hell with the 2" aluminum radiator...kyhatch01 wrote:i had a prob like that it was my gear settings and ect temp setting my car did not run that hot so i lowered the temp and bang good as new hope this helps
There are different thermostats open temperatures available thru Napa... you should change out for the highest value you can find to combat your radiator cooling efficiency.. or, during wintertimes, do like the truckers do and put a piece of cardboard or thin sheet of steel or aluminum in front to cut down the airflow thru the radiator. I have a similar problem with my fluidyne radiator.. when the car is hot & I take off hard, the temps drop quickly...
SpoolinSol
yea, i haven't changed the t-stat since i've owned the car (3 years) and i've meant to put cardboard infront of the rad, i'm just lazy2kCivicSi wrote:There are different thermostats open temperatures available thru Napa... you should change out for the highest value you can find to combat your radiator cooling efficiency.. or, during wintertimes, do like the truckers do and put a piece of cardboard or thin sheet of steel or aluminum in front to cut down the airflow thru the radiator. I have a similar problem with my fluidyne radiator.. when the car is hot & I take off hard, the temps drop quickly...
