I'm running 10ohm 10 watts inline resistors right now...maybe I'll take those out and wire up the honda resistor box to see if it'd make a difference.Bugermass wrote:Its not the duty cycle then, it has to be something with the way injector pulse width is calculated. OR mabey because o differences in impeadances with resistor boxes and what not the injectors arn't really active for the INJ PW that the ecu is commanding.. I don't know, but somthing is not correct..
Injector duty %
boostedeh2
Post your calibration...
boostedeh2
xenocron wrote:Post your calibration...
- gsr880b&mfpr.cal
- (8.18 KiB) Downloaded 244 times
well just tune.. you will feel when u run out of injectors... I can't explain why the duty sometimes show wrong(like this case)
boostedeh2
boostedeh2
I had the car on the dyno today and was having problems with fuel pressure drop. We adjusted to 45psi at idle and would rise to about 55psi but would started dropping fast in boost...the lowest we saw was 30psi so we let off. Thinking its the crappy b&m fpr or the walbro 255 went bad..I just put back the stock fpr but it doesn't run as smooth as the b&m.
