WEIRDNESS!!
b20beast wrote:
Gaskleppie wrote:
Bindegal wrote:It is highly unlikely that the temperatures you are seeing are caused by the software. FIX THE SENSOR OR THE WIRING. This sort of fault is not uncommon... /Allan
X2!!! btw, do you have a shortram intake? If yes, your temps are absolutely normal after a WOT run.
yes sir i do i have a short ram intake aluminum rad with pusher fan. also no heat shield on oem headers. Couuld i be needing to adjust battery offset? i see it fluctuates.
it could be but that means that the alternator is not really good. because the stock battery tables for stock injectors are perfect
b20beast wrote:How are you guys tuning idle AFR? Do you look at the 'display'? or do you log gear 0 ? my display, the afr fluctuates from like 14.6-15.3 at idle. should this be?
look at display and fix your altenator
b20beast
Post by b20beast »
From datalog, Battery Voltage fluctuates, The lowest and highest i seen is like 11.75 and highest 13.6 These are just the peaks, it might not be at one rpm 12.9-13.7 At idle. IS this normal? anyone have a map and datalog so i can see how my car sensors supposed to be?
during driving? do u have aem pulleys on your car?
b20beast
Post by b20beast »
no pulleys i posted a screen shot tell me if this is normal please
b20beast
Post by b20beast »
would a bad ground cause this behavior too?
yes
b20beast
Post by b20beast »
how does the battery voltage look? messed up? also how much should the battery voltage read?
b20beast
Post by b20beast »
alternator may be bad under WOT voltage drops to 12V's How bad would this affect AFR?
elevation
Post by elevation »
Lots. battery voltage should be 14 or so
b20beast
Post by b20beast »
no wonder im getting hell to dial in afr at part throttle thanks everyone :o
horrible bad
Bad ground would give spikes in the graphs. I dont see any so I dont think you suffer a bad ground.
b20beast
Post by b20beast »
Under corrections i see O2 Short Trim - Value 2 But 02 is disabled. Anyone know why?
not sure
