CEL light for O2 Sensor
JBird20
Post by JBird20 »
a log will do nothing..it will shop u a solid line and then a break showing the CEL...its only only comes on when u come on the decel....my 02 sensor is plugged into my harness..im gonna try to unplug it and see if it happens again
Sometime's there is more to get out of an log and an .cal then we (users) know of ;)
This O2 CEL is a weird thing. I have one customer driving for months in open loop, no CEL´s ever. And another costumer with CEL 1 coming up daily. He used to run ROM59, first in open loop, later with wideband closedloop, both causing CEL´s. Now we switched to Calvin´s special tip-in-fixed-ROM60+wideband closedloop but I don´t know yet if this fixed it.. stay tuned :) /Allan
Piv
Post by Piv »
Bindegal wrote:This O2 CEL is a weird thing. I have one customer driving for months in open loop, no CEL´s ever. And another costumer with CEL 1 coming up daily. He used to run ROM59, first in open loop, later with wideband closedloop, both causing CEL´s. Now we switched to Calvin´s special tip-in-fixed-ROM60+wideband closedloop but I don´t know yet if this fixed it.. stay tuned :) /Allan
I stay tuned Bindegal, but any explanation ? Still working ? I got the same problem today, disable everything but as soon as I disconnect the O2 sensor the cel light come on :?
send me log and cal pls so i can debug
Piv
Post by Piv »
I dont have a log but here the .cal
D16Z6 Turbo Alfonse ESI RR 0.62.cal
(8.18 KiB) Downloaded 275 times
Piv wrote:I dont have a log but here the .cal
can't do anything without log
I read something on an other forum. That the O2 error often comes when you have a AEM wideband connected to the ecu. When you go off the throttle it gives a certain voltage to the ecu which causes O2 errors. Can you confirm this?
My customer (car owner without standard o2 sensor) sold the car, crashed it, whatever so my diagnosis sort of stopped right there. Sorry. /Allan
I always use \"race only ecu\" and i've never had this random O2 problem..
Piv
Post by Piv »
Ok, I'll know next time And I'll try race ecu as well :wink:
b20beast
Post by b20beast »
i also get this cel it happens during decel i think i have lc1 wideband and use serial
