WEIRDNESS!!
b20beast
Post by b20beast »
hmm its weird
weird 02 correction
weird 02 correction
b20beast
Post by b20beast »
I once checked wideband as closed loop input but i press cancel.... dont know if its related
b20beast
Post by b20beast »
Ok i changed the alternator, got one from the junkyard. It still fluctuates, but not as much. Here is a pic, tell me if this is normal
wat is your avg voltage above 3k rpm?
b20beast
Post by b20beast »
Fluctuates in the range 12.9 - 13.5 3000-4500 rpm Ac on.
well it should be more in the region of 14-14.2
b20beast
Post by b20beast »
Could it be the alternator alone, or antything else.
check the wire form the ALT to the fusebox... look for any rusting or anything.... replace if you see it... tis worth the effort. Secondly, get your battery tested for CCA's... if good; then I would suspect the alternator for being bad; at anything above 1,500 RPM, it should be well close to 14.7v.. at the least 13.6, but that is on the extreme end of the low scale IMHO.
maybe he has alternator control shut off?
JDM doesn't have that..
b20beast
Post by b20beast »
i was thinking, I am using stock injectors. Is the stock battery offset table accurate? Or do they always need to be tuned? Still trying to figure out my inconsistent afr readings. btw, my alternator had bad parts. i will install it tomorrow and keep you posted. Stephan
let us know. and i found the 1.02 or 2% thing fixed it.
b20beast
Post by b20beast »
calvin wrote:let us know. and i found the 1.02 or 2% thing fixed it.
installed the alternator, volts are not in the 14V range under wot :( also idle, battery voltage tables jump from 14-12V i might need to tune the battery offset table to fix this inconsistent afr.
fix the problem where it is. It's charging, ground or something related. it should be 14.x V at idle
b20beast
Post by b20beast »
Not sure whats happening, took the car back to the guy who repaired the alternator. he put a meter on it, idle at high 13's Rev it, it stays at 14.0V I am lost I have been thinking My Wideband Gets power from A25----yel/blk------PGM-FI Main Relay (power) I Hope this does not screw up my battery reading And Wideband Ground is on A24
