Datalog will not connect.
dr_drache
I have a CRX with a OBD-1 Converted System. p28, chipped. and I cannot connect the datalogging port. removed and Installed drivers. Removed and installed 3 versions of windows. OST2 never failed to work in all test cases. HondaLog, seems to pass Loopback tests.(return CH in a terminal, open to hondalog COM port) Jaw Unit, Works every time without fail. before I got eCtune, I attempted to use crome free, and freelog, it ALWAYS came back with \"john cui datalogging script not found\", no matter combnation of versions, and script versions i used. I moved up in the world, coming to eCtune, everything is working out great, unless I need datalogging, (can't tune without it). so, here I am. any ideas?
From your post it´s unclear whether or not you have an eCtune ROM (Ostrich) in the ECU. Without the proper eCtune code in the ECU, eCtune on the PC cannot connect. Does your check engine light show that the eCtune ROM is active? You should see the usual long blink followed by 2 or 3 short blinks. /Allan
fix cel light first to be sure you run ectune. Key On how many flash do u see? including fuel pump prime? http://forum.ectune.com/viewtopic.php?t=1060dr_drache wrote:fresh CAL uploaded to the licenced and paired OST2, no CEL lights (think it's blown) port at 38400. car run's and drives with base CAL, (funny enough, better than the crome)
