Tip Out Trim, does it need negative (-) sign?
Got a simple question here. I'm wondering if the Tip Out trim value has to be entered as a negative number or not? In other words, if tip out is to subtract 10%, do I enter it as -10% or 10%
ive got a question about tipout. Currently i have it set to -95% and a tip out disabled below 1900rpm. I have tried disabling fuelcut to properly tune the tip out columns but even taking the values to 0, i still get AFRS dipping into the low 12s and high 11's. When i accelerate eve the least bit hard and immediately put the clutch in and let off the gas, they can even go into sub 10 afr. Is there something i am doing wrong here?
