Anyone have the Omnipower 3 bar map sensor settings?
Hybrid96EK
Post by Hybrid96EK »
Just like the title states. Got an Omni 3 bar map sensor here and I noticed its not in the list of maps in eCtune. I tried messing with the xenocron 3 bar, but that one isn't working. Car doesn't even idle. Let me know if someone here has the settings needed to get this map working. Thanks alot!
Its a motorola sensor so you can use that setting.
Hybrid96EK
Gaskleppie wrote:Its a motorola sensor so you can use that setting.
I see a Motorolla 2.5 bar, but nothing for a 3 bar. Will the values still be the same? If so, I can just set it up as custom and use the 2.5 bar values... but I was pretty sure they were not the same.
Hybrid96EK
I think I found it.. The max is 3000mbar, the min is listed as the same as the 4 bar, so 34.7. I will try it out later on tonight and report back!
Hybrid96EK
well that cant be it. With 34 or 35 in the 0v section the car won't even idle. fires up, revs a touch, the leans out horribly and dies. I can rev it, but even then it will eventually lean out and croak.. I'll keep looking I guess.
Hybrid96EK
Alright, I got it. The Xenocron 3 bar settings worked fine... I just forgot to adjust the scalar on the new map to match my old one! :)
