idle reving up and down, also tip out issue?
racepak
Post by racepak »
hello everyone. i have some issues with my tune. first off this is m setup: 75.50 vitaras on eagles. y8 camgear retarded 4.5deg on a 59300 cam (timing synced) miniram with t3/4 57 trim 780 precision injectors + resistor box venom IM (no iacv and fitv) idle is adjusted by the screw and a 8mm check vale in one of the vac ports, LM1(working gr8 with ectune :) ) ok, here are my issues. -sometime, after the car is warm (or after warmup) the idle revs up and down a bit, about 50 rpm-+ tryed to solve it ith fuel and timing but i didnt had any luck, -while idle if i jab the throttle very lightly to about 5% i get very rich afr's. also, tryed to solve it with tip in and tip out and lowering values on the map but it keeps doing it, the car dosnt stumble but its hella rich. i also need help on the fuel cut settings, but i need a log, ill take one tommorow. help and thanks :)
racepak.cal
(8.19 KiB) Downloaded 209 times
racepak
Re: idle reving up and down, also tip out issue?
Post by racepak »
log
idle head lights on and off.elf
(640.12 KiB) Downloaded 221 times
90$ of tipout problems(rich) can be solved by tuning the fuel maps col0 and 1
