ITB> First Tune - Help ! TPS INDEXING BUG !
Chris_rai
hi i'm going with my first attemp to make all thing to work. Ectune works fine, emulator is connected, hulog too, and my LC1 wired to the com port. Engine starts, runs on idle, just playing with + and - to set the AFR at approx 13-14 ( columns 0 and 1 ), runs fine, and after 2-3 mins it will shutt off ( injector cut ? ) Fuel & ign with TPS indexing hi cam only iacv just plugged on the engine harness Help thanks
- eCt.base273.cal
- basemap
- (8.19 KiB) Downloaded 271 times
- Piv
Hi Chris, I'm french if you want any help you can contact me [email protected] and we try to sort it out, I got basemap for ITBs
- Piv
Try the 62 Rom version and disable the fuel cut as well Parameter/fuel et ignition setting/fuel cut settings Hope it helps
