Think I found a bug in the new R9?!
Hybrid96EK
Post by Hybrid96EK »
calvin wrote:on the bottom of the screen you can see the reaming byte updates is that counting? Can u test with the current version on force update
I will check it out in a little bit. My car is currently out of service. Few hours from now I can check it out.
BlindFashion
Post by BlindFashion »
It was (havn't tested with force update. going to do that now) uploading on the byte counter but if you did a 5row 5column adjustment it would lag out and stop uploading..
it still had a problem. I just fixed it and test in my car. I'm uploading now so force update in 10 min
force update now
Hybrid96EK
calvin wrote:force update now
Ok. Just got done testing. Seems to work correctly now! Thanks Calvin!
NP
