Setting up boost solenoid
confUsed
So I finally got a chance to play with the ebc solenoid in the car yesterday. I set it up like the instructions says, #1 port connected to boost source, #2 source connected to top of the wg. Its a p28 ecu, and one of the wires from the solenoid is connected to 12v, the other to a11. I tried it before I started the car, and it clicks like it should when I set the duty to 50%. Once on the road, I hit boost cut like a wall at 0% duty. I tested different settings, and the only way I made it work is to set the solenoid to NO in the solenoid setting. I seems like its working now, I just wonder if I have done something wrong, or if its a bug? Does this mean that the ecu is grounding a11 all the time when not in boost? Could this lead to overloading something? I'll attach the cal and a log with a couple pulls.
- 3_31032009_1933.elf
- log
- (1.13 MiB) Downloaded 349 times
- start.cal
- cal
- (8.19 KiB) Downloaded 285 times
