Double minus number
Double minus number
Entering more than one - sign create an incorrect input string format.
OK i'll check
Bug verified
Also if you put somthing in the wrong field after a CTRL+J you have to put the box back to 0 before you can get out of it, it'd be better if you could just hit escape and it would let you out of the box with the value set back to 0. ... Sorry just saw the other thread about this.. but its not working on R7. .. is it gonna be on a newer version?
esc should be working checking now. This is r9.. Fixed
