Reinstall eCtune problem
Piv
Post by Piv »
Hi, I missed the last update and I tried to install it yesterday but it didn’t work So I managed to remove eCtune and made a clean installation So Remove eCtune, remove the In4tec data files Reinstall eCtune, run force update, 2r9 installed Replace the licence file Launch eCtune File/new And here I don’t have any base, I didn’t save them…:oops: And when I try to open an old rom you can see what happened on the attached files I had the same problem the first one I installed eCtune and the problem’s been solved when the end of the month came and I did run the force update But now I cant wait may as I would need eCtune at the end of the week Hope you can help me to solve the problem Thanks
1337EJ1
Post by 1337EJ1 »
Try to open your old rom with a unregistered eCtune on other PC just for test if its your old rom or eCtune who cause problem :wink:
Piv
Post by Piv »
Probleme solve thanks Synoptic :wink: and thank you 1337EJ1 for your answer :)
thnx nick.. to busy these days
Piv
Post by Piv »
calvin wrote:thnx nick.. to busy these days
No worries Calvin, its good to be busy :wink:
