my car runs great it drives great but for some reason it has no fuel cut when i let off the throttle it just goes to 10.8-11.2 thats where it idles i have 1000cc injectors on a built vitara setup. did i somehow disable fuel cut? thanks
did you play with fuel cut in parameter ? run your car , datalog , look at map value when decelerating and then set you fuel cut value a little bit higer than your datalog regards
ok ill try that and see what happens. i will run a datalog and post my cal and elf files if you would look at them and see how it looks that would be great.
