AFR Overlay & Datalog Replay ?
- 1337EJ1
Hi all ! First, sorry for my bad English. I have an question. Last day, i make an record of an datalog session. So i save my .elf for modify my map after @ home. At home, i launch eCtune, open my ROM and open my .elf session. Is it possible to full complete the AFR reading WITHOUT play all the datalog session ? Or must i play the complete session ? Thanks !!!!
there should be an option to parse datalog on open. See settings. if enabled it will read the afr and plot it on the afr reading grid it will also plot the peak values
Is it possible to have an message stating eCtune is parsing the log when you got it switched on? And maybe where to shut is off. That would make things clear and give the user the reason why its loading long and where to shut it off.
Or maybe an switch when you browse for the log to enable or disable parsing of the log. Just trying to think along.
