TIP with Timing MAP
b20beast
TIP with Timing MAP
Hey guys, SO i have been wondering, How do you guys add timing in the boost portion of the timing maps? Lets say i want to add 5Degrees at 6PSI. I do not want the lines crossing. Should i select the entire map and add the same 5 Degrees? i hope you understand what i am trying to say
thanks
- Piv
I generally add the timing 2 degrees by 2 degrees If you're line appear to cross thats because you could add more degree at less pressure ! BUT, it doesnt mean you may add 2 degrees everywhere ! Be careful about this because you could make it detonate like this Tune your low load first and when its done do your WOT When both done, do a balance between each line but they shouldnt cross each other
Hope I'm clear
- Piv
Try to tune the low load on the road and just go on a dynojet for the WOT I've never use it before so I cant really help but thats what I would do esle you could try to find a dynodynamics or dynapack around your areab20beast wrote:Im not sure how to tune low load on a dynojetI think that can only be done on a load bearing dyno But thanks alot for the help along the way! much appreciated
- Piv
Det can or EGT If you dont have any of them check your plugs
And if you really dont know just leave it as the basemap was
