ARF CHANGE with SAME Bat Voltage and ECT, IAT
				b20beast
I have a problem with Consistant Idle ARF.      At Idle around 850rpm  The Afr Fluctutates  The Battery Volt is the Same  ECT and IAT Are the Same    Goes 14.48-14.98 AFR
- AFR
 - afr.JPG (147.45 KiB) Viewed 6360 times
				greasemonkee
				Adam Hopkins
You will never get it to be 100% rock solid. It is not Calvin's, eCtune's, or your fault. I have tuned vehicles on about 15 different types of software and I ALWAYS see small fluctuation in afr's at idle.    Do not get me wrong, a small blip from 14.4 to 14.8 is ok, but if it is jumping a whole point or something more extreme then it is usually a compensation table you need to adjust.
									Regards,  Adam Hopkins  eCtune Team  eCtune Authorized Tuner  Location: Murfreesboro, Tn, USA
