FTS/limiter question - confusion
greasemonkee
Post by greasemonkee »
I've never messed with the FTS until now. I find it strange that if the rpm during a shift is over the resume rpm, it still blips a little fuel and consequently rpm do not seem to drop as one would expect.
Blowupsoon 17.cal
(8.19 KiB) Downloaded 237 times
I just tested on the bench FTS set to 4000 rpm Tps to 50%. if tps< 50 % and rpm >4000 it cuts to 4000 rpm and restores the cut if rpm <4000 if it goes above 4000 rpm it cust again. see log.
fts.test.elf
log
(81.63 KiB) Downloaded 228 times
test.rom.tps.0-100%.egr.duty.cal
cal
(8.19 KiB) Downloaded 251 times
can this be tested with the 0.0.2.2r3 that will be released now?
greasemonkee
The last .cal I made was with ver 0.0.2.2r8 . I'll have to retune for current version? If not I can test.
greasemonkee wrote:The last .cal I made was with ver 0.0.2.2r8 . I'll have to retune for current version? If not I can test.
no retune required. send me your cal by mail
