try r3 the current version. then report back. make some logscombz wrote:calvin i have logs of version r1, fuel cup is working better than it was when i was tuning my car last year...its not as violent of a shaking when fuel cut goes off and on..but you can still feel it a bit. i updated to r3 today..i'll test and make a few logs and see if there is any change. when i post a log to help out do i need to post my map too?
fuel cut tips
okay, i am not sure if i used the right sequence to actually update the tune on my ostrich, i saw how to do it a few weeks ago.. i updated ectune with force update opened my saved tune on my computer * got some message about a mixup between cylinder numebrs on something..\"do you want to continue\" something or rather.. - i hit yes -i put rom to my ostrich.. should it now be latest version? I turn my Key on egnition off (KOEO) i get three flashes on my MIL short ones.(indicating version r3 of ectune?) Fuel cut still does not work. Have not had time to make logs yet, will try to do it on the way home from work today and post tomorrow. Can still feel it going off and on like 30 times, worse when car is cold off throttle. Its better, but still not completly fixed. will post logs and cal tomorrow.
okay i ran force update the other day. i will run it again but first i will show you the details on it currently and post a log i took yesterday. in the software i go to the help menu, check for update, it says \"you have latest version...\" i right click on the ectune application it says date created June 15th, 2009. i open ectune . version is 0.0.2.3 r3 here is my log from yesterday. context is driving on highway. map has barely been tuned as far as timing goes, and only 7 psi. ill post both. now ill run force update and do another log, same conditions on the way home, and see if there is any change.
- home_23062009_1848.elf
- fuel cut.. i didnt notice it too much..but the log shows it going off and on, highway driving, me of
- (349.98 KiB) Downloaded 636 times
- 3BarMap750ccGt3076r63ar.cal
- (8.26 KiB) Downloaded 523 times
oh and here is another log...the last one was in fifth gear maybe fouth im not sure.. this one is off the throttle in 3rd gear i think..and fuel cut does not go off or on.
- home2_23062009_1923.elf
- (193.77 KiB) Downloaded 534 times
ok awesome, i went to do a force update...and the progress bar did not move.. it got maybe 1/6 done then stopped moving. it froze.. i clicked the x box to close it..it closed now i cant open ectune anymore. says some setup file is missing.. oyy..
sweet. the actual ectune application is missing from the ectune folder in program files... do i have to reinstall it? if i do won't my license file be invalid? ill pm you if i cant get it working again after reinstalling EDIT: i reinstalled it saved my license file before i did it, and it appears to atleast boot up again. Crisis averted hopefully..ill try to see how it works on my lunch break.
force update to have the correct update.combz wrote:ok awesome, i went to do a force update...and the progress bar did not move.. it got maybe 1/6 done then stopped moving. it froze.. i clicked the x box to close it..it closed now i cant open ectune anymore. says some setup file is missing.. oyy..sweet. the actual ectune application is missing from the ectune folder in program files... do i have to reinstall it? if i do won't my license file be invalid? ill pm you if i cant get it working again after reinstalling EDIT: i reinstalled it saved my license file before i did it, and it appears to atleast boot up again. Crisis averted hopefully..ill try to see how it works on my lunch break.
if you are sure this is the latest version. i'm willing to send you a test bin to debug this futher... Everything looks good. I did not encounter this when i tuned a car 2 weeks ago. I have one todo tomorrow. But i'm willing to debug with you. Calvin BTW try 225 mbar.combz wrote:oh and here is another log...the last one was in fifth gear maybe fouth im not sure.. this one is off the throttle in 3rd gear i think..and fuel cut does not go off or on.
i forced update yesterday uploaded the new version on my ostrich..problem persisted. i'll change to 225mbar tonight, im going to try to get my ectune boost solenoid working too. also i uploaded my .cal file along with the log, cant you tell what version i was using? i'll still do more logs tonight.. i notice the problem violently shakes the car, say if im slowing down in third gear and i let my rpms drop to 1200 rpm, the car shakes like its exercising a demon.
logs i might be car related i need more testers. I'm testing to night my self.combz wrote:i forced update yesterday uploaded the new version on my ostrich..problem persisted. i'll change to 225mbar tonight, im going to try to get my ectune boost solenoid working too. also i uploaded my .cal file along with the log, cant you tell what version i was using? i'll still do more logs tonight.. i notice the problem violently shakes the car, say if im slowing down in third gear and i let my rpms drop to 1200 rpm, the car shakes like its exercising a demon.
i have more logs from last night, will post when i get on my laptop at noon. Fuel worked great sometimes...other times not so much, thats why its deciving it appears to work like its supposed to most of the time. then sometimes it still cuts in an out..i'll post all my logs last night, showing good workign fuel cut and bad. two hours..from now.
